What would be an upgrade from an AC Freezer 7 Pro? (LGA775)
452 Views 8 Replies 6 Participants Last post by  stanglx302
I'm trying to get to 4.0Ghz with my quad, but I'm running to hot IMO. I have the Arctic Cooling Freezer 7 Pro (v1). What would be an upgrade from that? Please post a link if you can.
1 - 9 of 9 Posts
although the freezer 7 is a very good cooler for the price if you want to go further i'd be looking at the zigmatek dark knight, the thermalright TRUE and the mugen 2. Take whichever one fits in your budget range but they all are brilliant coolers.
The Titan Fenrir is meant to be quite good also.
CM Hyper 212+, Dark Knight, or Mugen 2 on a low budget.
Megahalems are the best overall.
Almost anything..lol Seriously though a TRUE or a Prolimatech Megahalem would be my frist choice.
I wouldn't be saying that about the ac freezer, it is a very good cooler for the money (got mine for $20au) and still keeps mine very cool(about 8c above ambient at idle when overclocked). Overall if you are short on money the freezer line is perfect so please don't put it down
Yeah, too bad idle doesn't mean anything.
@ OP
TRUE or mega would be your best bet. or A Xigmatek if your budget is semi-low.
I'd forgot to list my load temps, i get around 64c when overclocked with ambients of about 25c, its not too shabby for a "low" quality cooler
Thanks to everyone for the help. I just have to get some measurements now and see what is going to fit.
1 - 9 of 9 Posts
