What would fit this budget?
451 Views 11 Replies 12 Participants Last post by  Shift.
Hi, pretend you were given $300 to buy an AMD CPU and Mobo. What would you get?
1 - 12 of 12 Posts
http://www.newegg.com/Product/Produc...82E16813128384
ud4 is where it's at
what K3VL4R said --down there --V
I had too many tabs open and pasted the wrong link
http://www.newegg.com/Product/ComboD...t=Combo.165050
The 790FX combo is only $6~ more. (and it has a $34 MIR you can use)
+3 :d
Newt's motherboard pick and 7750BE. 100 dollars left over.
Depends on what you're doing.
For multitasking I'd get the Quad. But for games and such, the X3's really shine.
Personally, I'd go with an X3 720BE and a DFI Lanparty DK 790FXB M2RSH.
That is, if you're sticking with DDR2. Otherwise I'd get either the Gigabyte MA790FXT-UD5P or the MSI 790FX GD70.
1 - 12 of 12 Posts
