What would happen if there was at least 3 CPU Socket Pins(LGA775)bent?
464 Views 3 Replies 3 Participants Last post by  computerfreak09
Would there be a chance that it would burn the processor to death?Would it work and nothing would be happening?
Well technicly im asking
can the processor be burnt with Bent Pins from the Motherboard?(ANY LGA775 MOBO BECAUSE THOSE MOBOS HAVE PINS ON THE BOARD FOR PROCESSORS TO CONNECT TO)
1 - 4 of 4 Posts
I've never had any bent pins on an LGA775 but I will say that if I noticed some during a build I would not even bother mounting the processor.
Believe it or not, with a small flathead screwdriver, you can bend them back. Like an idiot, I bent about 5 on my 750i and I just used a small flathead screwdriver and bent them back VERY slowly and VERY carefully and to this day, it works amazingly. If you left the pins bent out of shape, it MAY work, but 99.9% chance it will just not POST. Happened to me as well, if you can exchange the board, do so, if not, then just be REALLY careful and bend the pins back, it will work as if it were never bent. The only thing I would be concerned about is hurting the mobo, processors are pretty resilient, but even then, in this case, I wouldn't worry at all. Hope this answers your question ^.~
Reactions: 2
Thank you!Finally a good post REP+ for u
and yeah ill try that some day
Thanks Again
Props to u
1 - 4 of 4 Posts
