1 - 20 of 21 Posts
I had a question... My 3700 is clocked at 3.024 and I was wondering what it compairs too... I was thinking about an upgrade in the 939 range, but if this will do just fine compared to lets say a dual core then I don't think I'll upgrade. I just wanna know what would be my next step I could take to improve performance on the 939 side. Dual core maybe??!!?? FX maybe??? Opteron??? Please help me <img alt="" class="inlineimg" src="/images/smilies/grouphug.gif" style="border:0px solid;" title="Grouphug">
Only thing that would be better would be an FX57 on phase (most aren't cold bugged, unlike 3700+s), or a dualcore at 3+ Ghz. Probably a 165. I wouldn't upgrade within 939, though. 3 Ghz is fast enough to hold me over until K8L or my core 2 setup.
Wow a fx57 on phase <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps">. I was looking at the x2 4800 toledo on newegg, would that be anything different? Some of the reviews says is a great cp just not that great at oc... Just curious <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
I doubt you'd get much higher than 2.7 with the 4800+... if you're going dual core, get a good Opty 165 stepping.
I agree with Namrac. If you want to upgrade your current 939 get the Opteron 165, they are fairly cheap now and if you get a good stepping you can hit a nice OC.<br><br>
I can hit 3.0 + with my stepping but keep it at 2.9 with stock vcore (1.375). I need to crank it up to 1.55 vcore to get at or above 3.0 but can easily be done.
Yeah most S939 chips wont go past 3.0GHz or so. You could increase performance by going to a dual core opty but apart from that your at your limit already <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
I'd be looking also at a Opteron 165 or a X2 4400+Toledo given a suitable purchase price.
Some of the X2 3800's will run at 2800 MHz+. For the price you are on a winner surely. Even mine at 2400 (or less) feels to have the edge on a single core generally.
You can't really benchmark a single core cpu against dual core imo, it's faster than an FX-57 (which is 2.8Ghz stock). And that CPU was the dogs b*ll*cks this time last year and would be enough for the next year or so. The only thing i would recommend is getting a better GPU.
Honestly from my own experience I'd stick with the 3700 since I really haven't noticed much of a performance increase with general PC usage (not counting Super PI or any other benchmark) at this present time. But with the 165's so cheap nowadays it' not a horrible idea to upgrade either. So flip a coin and if you do get a 165 from a retail store, hope for a good stepping.
Opteron 165<br><br>
Ony $160 now, and with a good stepping 3.0GHz is possible<br><br>
Dual core folding! Yeah
<tr>
<div>
Originally Posted by <strong>tuchan</strong>
</div>
<div style="font-style:italic">Some of the X2 3800's will run at 2800 MHz+. For the price you are on a winner surely. Even mine at 2400 (or less) feels to have the edge on a single core generally.</div>
</td>
</tr>
</table>
</div>Yep, at around 2.4GHz is when these X2 3800+s start to feel fast. I hit 2.8Ghz the other day. They are very cheap for the performance you get. <br />
<br />
Lonnie5000 hit 3GHz the other day with his X2 4200+ Toledo on stock voltage. It appears he has a rare chip because I hardly see any with higher overclock than 2.6GHz, but who knows. It could be a new 3700+ SD thing.<br />
<br />
EDIT - but if you can get a Opteron 165 for $10 more, go for it. 1Mb L2 cache per core.
Discussion Starter #14
<tr>
<div>
Originally Posted by <strong>Mhill2029</strong>
</div>
<div style="font-style:italic">You can't really benchmark a single core cpu against dual core imo, it's faster than an FX-57 (which is 2.8Ghz stock). And that CPU was the dogs b*ll*cks this time last year and would be enough for the next year or so. The only thing i would recommend is getting a better GPU.</div>
</td>
</tr>
</table>
</div><br />
Why would you recomend getting a better gpu? This things only 3 months old and is great... Also which would be better: $160 upgrade or $400 easy on a better gpu??!??<br />
<br />
I don't even have this gpu oc'd at all and everything I play with maxed out settings at 1280x1024 I don't get any "blips" in frames.
That GPU is fine. The best upgrade would be a dual core CPU. Any single core CPU (including the FX series) will likely run mariginally faster than your current 3700+ when overclocked (if you can hit over3.0GHz with the FX's that is).<br />
<br />
Your video card is good enough for now. To see a substantial improvement, you'll indeed need to spend $400+<br />
<br />
Go get that dual core CPU. Only upgrade that makes sense to me.
<div>Originally Posted by <strong>Chozart</strong></div>
<div style="font-style:italic;">That GPU is fine. The best upgrade would be a dual core CPU. <b>Any single core CPU (including the FX series) will likely run mariginally faster than your current 3700+ when overclocked (if you can hit over3.0GHz with the FX's that is).</b><br>
Your video card is good enough for now. To see a substantial improvement, you'll indeed need to spend $400+<br><br>
Go get that dual core CPU. Only upgrade that makes sense to me.</div>
</td>
</tr></table></div>
How would a 3.0ghz FX run faster than a 3.0ghz 3700 SD?
Wrong phrasing. Sorry <img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment"><br><br>
what I meant to say is that you likely won't be able to overclock the FX series CPUs much more than his current 3700+ Sandy. With this possibly higher overclock, they'll run marginally faster (let's assume he gets 3.1GHz v. his current 3.0GHz on the Sandy - that's a marginal difference in my opinion, not worth gettign a new CPU for)<br><br>
Sorry for being unclear
<div style="font-style:italic;">Wrong phrasing. Sorry <img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment"><br><br>
Sorry for being unclear</div>
</td>
</tr></table></div>
Its fine, no worries. I understand your point now, and would have to agree too.
But 3.1 GHZ dual core will best that 3ghz single twice over...
That's why I suggested the Opty 165 <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
1 - 20 of 21 Posts
