The title says the question. What would you do. what would you buy (keeping on the topic of PC's). What system would you buy, what cooling sytems and so on.
To start with. I think i'd get an Asus P5AD2 Premium. A 3.8Ghz 570J. would request a Unlocked P4 From Intel by offering a large amount of cash. DDR2 733Mhz RAM. I would then get a 4 74 GB 15,000RPM Hardrives. I Would buy a custom Vapochill System. Keeping things small but in the -Temps. I would get a 400Watt+ Peltier. I would then a liquid nitorgen water cooling system with Face playes with go on the back of th motherboard and Graphics card. The Plates would be about 1cm think and be like a heatsink but really big that pumps Liquid Nitrogen through it. From there I would start ocing by first razing the Vcore to 1.8Votls. I would then up the CPU to 300Mhz straight away. Then i would try to get as higher FSB as i could.
After i got board with that, I would get a custom casing that made a tight water proof fit around my motherboard. then get a enclosed tub of Liquid Nitrogen and chuck in the Motherboard with the top of the CPU exposed to raw Liquied Nitrogen. I should get atleast -200C temps with that at full load. then iw ould try to get as higher FSB i could get by rasing Vcore upto 2Volts. By the way. The cables would be connected to the motherboard using sealed holes with the cable running in the Mobo Case and onto the board (for all cabls). Imagine the clocks you could get with that. Feel free to post your most crazy PC stuff if you where rich (billions Rich).
