1 - 20 of 24 Posts
Whats a good cpu temp for a P4 2Ghz Northwood right now 2 of my programs are saying the cpu is at 43 the bios is saying 49 which is right, whats a good temp (no thermal paste and would like to up it a bit) is 55c okay???
Thanks in advance
Originally Posted by digitalphreak
What you mean no thermal paste????
well he's not online anymore, maybe his cpu fried LOL.
Thanks in advance
Northwood's shouldn't get over 55C for sure. I keep mine at 50C right now under full load, but that'll change as soon as my Thermalright XP-120 gets here.
I'd say you're crazy if you're runnin your processor with no thermal paste...get some AS5 for sure.
mate no thermal paste u wud probably do better without a heat sink lol.
metal to metal wud conduct sh**t loads of heat. your cpu should be running under load at around 50 degrees with stock cooling and no overclock.
im on Intel 3.0EGhz , my idle is 58 and my load is 78 .... do you think its normal ?
im on stock cooling.... i just find it damn high.... maybe there are something wrong with my cooling or was it suppost to be that high ... ?
Administrator
I think that is quite high. I have a Precott 3.2GHZ and that is 46C at load. Shouldn't really go above 65C
Originally Posted by Austin
it could just be seated wrong, before you go buying as5 (which i suggest you do anyway) trying reseating the heatsink
i tried...
i try it again later...
Linux Guru
i tried...
I say buy a new HS, and set it using AS5, remember put a BB sized drop of AS5 in on your CPU and press the HS on to keep from making bubbles.
talking about the AS5... bout the greezz thingy... i might have found the problem ...
hehehe ... i dont remember applying any greese on my processor when i install the system
i guess thats the problem ...
man ... after 2 years using this comp
hehehe i got lucky without burning it...
Linux Guru
You got really lucky.
Well, you installed the stock HSF right? That comes with a thermal pad attached so you don't need to apply paste.
Linux Guru
I've only seen the thermal pads on Socket A P2s and P3s, I beleive that they stopped using them because they don't allow enough heat conductivity.
i checked... and hey... now i see why i never apply the thermal paste... because it comes with the thermal pad like what idiotec just mention. ... well... maybe wasnt my problem anyway ... i got some excess thermal paste from b4... i removed the heatsink and apply some on it. and put it back on again .... and changing the chassis fan from drawing air out from the comp... i make it blow in cold air instate... my temprature droped to 51°C from 58°C ...
comments ?
i have 3.6 p4 precott, it runs at like................. 55-69 with just stock hsf and no case fan (it didnt really have any fans. there was no case. it just got delivered 3 hours ago... *preys to god that its inside cuz its snowin like the dickens outside and it was 100 dollars and has a psu and cpu inside...... *runs from school to go shove the 50 pound box inside the door and runs back to finish the last 33 minutes of school *yawns and gags.. studyhall sucks balls*
1 - 20 of 24 Posts
