I want to reach 4.0ghz on my 920 with C0 stepping. What heat sink would allow me to reach 4.0ghz? I'm on a fairly tight budget so cheaper is better
C0 is an older stepping and generally needs a good deal more vcore then a D0. Where a D0 can hit 4.0Ghz with something in the 1.25-1.40V range while the C0 usually sits in the 1.30-1.50V range or might not run at 4.0Ghz at all.
Honestly, I would rather get an Hyper 212 Evo which is 2x cheaper than the H50 and has a better fan.Originally Posted by Obsuniva
Oh, and running an h50. Pretty good cooling if you ask me.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010
49.99 after rebate.
