what's better and why?
460 Views 5 Replies 4 Participants Last post by  ny_driver
athlon 64 x2 4200+ Toledo, or the Manchester core? The specs are the same.
1 - 6 of 6 Posts
The Manchester is single-core, the Toledo is dual-core.
What he said ^^^
the Toledo is dual core and therefore obviously better than a Manchester
the specs I read at newegg were the same I'm pretty sure. Thank you. EDIT: I think they are both dual-core
An Opteron 170 would be better I think anyways with the larger L2 wouldn't it?
for sure. And not to mention the 939 opterons are generally able to oc to 3ghz+.
I should be able to use an Opteron, I think...my board supports 64 x2 939 pin...what else would stop me?
1 - 6 of 6 Posts
