Whats better then an Ultra kaze?
376 Views 1 Reply 2 Participants Last post by  rpgman1
alright i originaly had 3 ultra kaze 3000's on my rad. since my rad is in the front, i switched it to 3 antec tricools, and they are totaly crap, when you turn up the fan speed all it does is make more noise instead of move more air, now is there a fan out there that has blue led's and has a high static pressure?
also what other fans are there that are a bit quiter then an ultra kaze but yet perform at the same level
1 - 2 of 2 Posts
Ultra Kaze fans are very loud, you should go for San Ace and Panaflo fans if you want less noisy fans.
1 - 2 of 2 Posts
