I haven't been keeping up with the best and newest CPU blocks. Just wanted to buy the a new block that is under $200.
Too bad they left a few key blocks out that still perform great like the Rasa. The Rasa and EK block perform right up next to each other. One thing I don't like about these studies is how much they adjust the scales to make the difference look larger then it really is. For example the top 5 all perform within .59C which won't be noticeable and will change depending on the mount and other variables.Originally Posted by coolhandluke41;14180188
for 200$ you can get 2 CPU blocks but the top thermal performing blocks are
Kryos HF
KL 370
EK HF
http://skinneelabs.com/2011-cpublock-compilation/2/
