Whats the best Antivirus/adawarfe/registry cleaner !!!!!
957 Views 4 Replies 5 Participants Last post by  DEC_42
like the title says , anyone ?
1 - 5 of 5 Posts
AVG Antivirus
Malwarebytes for spyware
CCleaner is good for reg cleaning.
HijackThis for registery cleaning and problem finding
Norton's 2010 products are very good... Norton 360 has a registry cleaner, too.
If you're looking for free solutions, try CCleaner for your registry and Avast! for your antivirus.
NOD32 is an amazing antivirus. If you are going free protection, Avira ain't bad.
Malwarebytes is a given. Spybot search and destroy is also good. And as mentioned above, CCleaner.
Wrong section, by the way. Not much else to say aside from the above. I use NOD32 with Windows Defender and Windows Firewall myself.
1 - 5 of 5 Posts
