Hey guys, if you want to post your batch numbers here and Highest stable OC, I'll keep them in post #1 for quick reference. We'll see how the batches hold up to the OC's.
Intel CPU Info
Detailed Info
Here is a great thread by linskingdom on 45nm processors.
I believe this is a record!!
For those with temperature/voltage questions or issues with these CPU's, you might wanna read the following:
My Personal Proof that the Core Sensors are off
e8400 Overheating
Flawed Core Sensor Diode
More Core Sensor Diode Info
Penryn Delay Due to Core Sensor Diodes??
Link 5 (read through)
Tricky's E8400 "Crapped Out"
How To Properly Apply Thermal Compound
Please note, that by sayiing "Official" below, I don't mean that it will be published worldwide on any websites or anything like that, it's just my way of saying thanks for posting your OC's here!
Enjoy!!
Kaxx
Ultra-Official Listed CPU's by highest OC/lowest Vcore
8 Hour Orthos or Prime 95 Stresstest
Q746A377 = 4.20 GHz, 1.3600 volts kaxx
Q746A377 = 4.05 GHz, 1.3520 volts JustMe2
Q745A553 = 4.00 GHz, 1.2400 volts Spinach
Q745A553 = 4.00 GHz. 1.3100 volts zlojack
Q744A761 = 3.90 GHz, 1.4000 volts Clox
4-8 Hour Orthos or Prime 95 Stresstest
Q745A567 = 4.05 GHz, 1.2480 volts ThatGuy16
Q746A489 = 4.05 GHz, 1.2800 volts Bulldog 22
Q744A761 = 4.05 GHz, 1.3900 volts x2s3w4
Almost Un-Official Listed CPU's by highest OC/lowest Vcore
Less than 4 Hour Orthos or Prime 95 Stresstest, or at least a screenshot of CPU speeds.
E3110 Q750A158 4.40 GHz, 1.37 volts Geekman
E3110 Q805A165 4.10 GHz, 1.37 volts MADMAX22
Q745A567 = 4.05 GHz, 1.2720 vix
Q748A115 = 4.05 GHz, 1.4400 volts Carpenter]
Q806A026 = 4.00 GHz, 1.3125 volts mothow
Q805A249 = 3.80 GHz, 1.2720 volts tetemagique
Q808A169 = 3.00 GHz, 1.1000 volts kpo6969
Un-Official Listed CPU's by highest OC/lowest Vcore**
No Stresstests provided i.e. word of mouth (but it's never too late)
Q746A488 = 4.50 GHz, 1.4685 volts c230K
Q746A519 = 4.30 GHz, 1.3900 volts NCspecV81
Q751A447 = 4.20 GHz, 1.3930 volts Celoth
Q743A748 = 4.13 GHz, 1.3375 volts iewgnem
Q743A748 = 4.05 GHz, 1.3500 volts Ledge 68
Q746A377 = 4.00 GHz, 1.3000 volts mct75
Q744A698 = 4.00 Ghz, 1.3000 volts viceroy
Q740A525 = 4.00 GHz, 1.3000 volts Oblivion77
Q746A366 = 4.00 GHz, 1.3700 volts Rolandoo
Q746A483 = 3.78 GHz, 1.3000 volts
Q746A489 = 3.60 Ghz, 1.1850 volts lenzo
Q746A519 = 3.60 GHz, 1.1250 volts Jarrsten
Intel CPU Info
Detailed Info
e8400 Overheating
Enjoy!!
Kaxx
