What's the Best Fan Controller for the Money
691 Views 10 Replies 8 Participants Last post by  ukic
I'm thinking of getting a fan controller and was wondering what you guys would recommend? I want it to be able to take both a three and four pin connector as I have a combination of those fans in my case. At first glance the NZXT Sentry 2 seems to be my best option (it takes both connector types, is fairly low priced, has a touch screen, and looks pretty sweet). What do you guys think?
1 - 11 of 11 Posts
It's 10watts/channel, for looks, yes but for performance, the sunbeam rheobus I heard is really good and its cheap ($14) and its 20watts/channel.
I would go for this Sunbeam, or a Lamptron.
Reactions: 2
http://www.newegg.com/Product/Produc...82E16811999197
I've always fancied this one myself. But its something I have on my wishlist for my next build. It wouldn't look good in a black case, and its kinda expensive.
I second this. I personally use the rheobus but I've heard great things about the lamptrons.
If you want touch-screen, then this NZXT LX is decent.
Syrillian thanks for the link to the Lamptron, I have been looking hard for a 6 channel controller (3x120 push/pull = 6 fans) not only is it 6 channel but 45 watts,that 45 figure must be overall and not per channel,but maybe +rep
Originally Posted by PCCstudent View Post
Syrillian thanks for the link to the Lampron i have benn lookin hard fot a 6 channel controller (3x120 push/pull = 6 fans) not only is it 6channel but 45 watts,that 45 figure must be overall and nor per channel,but maybe +rep
It is per channel, but not recommended to exceed 75 watts total (it's possible, though).
Thanks for the suggestion guys. What's with the per channel rating. Does that really matter much if you are only going to use one fan per channel? I have two 120mm, two 140mm, and one 230mm fans.
You should be fine if only you use 1 fan per channel. Some fans eats power like panaflos, san ace, ultra kaze. Basing on what I've read, it burns your fan controller if your fan controller watts gets over loaded.
1 - 11 of 11 Posts
