1 - 16 of 16 Posts
I have a bunch of .mkv files that I would like to convert to other formats like .avi or mp4..
I have tried to install TMPGEnc, but it will not start and Movavi doesnt recognize .mkv files..
Thanks
That's not a video converter. And you should give up on CUDA encoding, right now.
This
What's so terrible about CUDA encoding? o_O
In short, it doesn't work. As far as I know it is fairly difficult to implement video encoding on a GPU, as the algorithms aren't easily parallelized. There is a program called Badaboom, but compare it any CPU-based video encoder and the difference is like night and day.
Discussion Starter #9
IDK, media show expresso works pretty good.. Its a lot faster than avs video converter thats CPU intensive..
Originally Posted by HondaGuy View Post
^^^^ I agree, using Media show expresso here with Sapphire cards, can recode a PS3 movie in under 20 mins 1080p
Can use NVIDIA CUDA or ATI Stream
http://www.cyberlink.com/products/me...iew_en_US.html
Just started using this program. It says that it utilizes up to 4 core cpu's so does that mean it doesn't use Hyperthreading? Would it be beneficial to have HT on while using this? thanks
MediaShow Espresso delivers a breakthrough increase in performance for HD video conversion of up to 162% by channeling the full power of the CPU. By taking advantage of Intel's multi-threaded computing technologies, MediaShow Espresso gives you more time to share and enjoy your HD videos and less time wating for them to be converted.
MediaShow Espresso Utilizing 8 Computing Threads
You can recode UP to 4 at once...
You're silly for looking at the % of CPU usage rather than the speed. I bet x264 can beat that program's speed with only 2 cores.
But if you wanna have silly CPU load competitions, x264 can use all 8 hyperthreading threads, and it won't dip like you see in that graph. It'll be a nearly flat line at the top.
Let's see: that first episode has a duration of 23:35 and it probably runs at 30 fps. That puts it at about 42407 frames. 12% completed, so there are 32318 frames remaining. With 7:18s remaining, it's going at 85 fps. Multiplied by 4, that's 340 FPS. I can see the ugly artifacts in that tiny, resized preview, so that means it's probably really bad quality. It's a scene rip, so the resolution is likely something like 576x432. It's safe to assume x264 can soundly defeat it at quality and speed, at the same time.
Just run x264 or whatever multiple times?
There is nothing inherently limiting you from doing more.
Originally Posted by F1ForFrags View Post
You are OCN's 10,000,000th post.
Congrats.
What do I win,LOL
1 - 16 of 16 Posts
