What is your use case and your budget.https://youtu.be/UyTX0DaVcyo?t=111
i'd like to try this following build or anything that's more silent than it
Wondering what's the difference between the 2 cases? I see a review saying not enough space for the ssd, wondering if the 120$ one has space for it? or else i guess i'm going for an m.2 drive
https://www.amazon.com/quiet-BGW06-...=1518447611&sr=8-6&keywords=be+quiet+600&th=1
vs
https://www.amazon.com/quiet-BG021-...8&qid=1518447611&sr=8-2&keywords=be+quiet+600
Are there any more silent cases than these? I have reactive tinnitus so i'm trying to find the most silent build possible when the new gpus/cpus are out
Thanks for your suggestions
If you're going to load the machine heavily and you want dead silence, a custom loop is a compelling option. I have yet to find an air cooled GPU that even comes close to a card with a full cover block.
