1 - 2 of 2 Posts
is vccio and cpu system agent it takes on the memory controller on the cpu right? so with that change are voltages above 1.35 for dram voltage safe? what about 1.5 dram voltage on an intel 8700k for moderate to heavy load 24/7 operations what dram voltage is safe
Senior Overclocker
No more than 1.5v is reasonably safe, with some airflow around them.
You can see some extremely overclocked sets of rams are running a default 1.5v. I wouldn't go over this setting.
1 - 2 of 2 Posts
