1 - 16 of 16 Posts
Just got some of the Liquid Metal and wanna make sure the IHS on my AM2 chip isn't made out of aluminum.
Nickle plated copper. The nickle is just for anti-corrosion.
Discussion Starter #4
Cool thanks guys...you think I should lap it <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> , the cpu that is or is that not worth the trouble.
Yes a CPU lap is a good idea. I have had one that was not flat at all, it took me a while before I realised that was the problem.
Bod ***s rock
yeah lapping it would give you better temps just dont try to remove it as i have heard AMD has started soldering the IHS to the die
Discussion Starter #7
Any tips on where to get a good piece of straight glass and the sandpaper?
To shed some unwanted degrees, anything is worth it. Higher OC's ftw!
easypckits.com has good kits with all you need. glass, and lots of different grit paper... all for about $15. Its what i used on my IHS, and it blings! plus a ~6c drop in temps.
Discussion Starter #10
Found the place u just mentioned while i was floating around the web <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> Sweet package, just what's needed and best of all I dont have to hunt all that crap down. Think I should lap my scythe ninja too? It looked pretty damn straight and had a good shiny finish.
<tr>
<div>
Originally Posted by <strong>Bitemarks and bloodstains</strong>
</div>
<div style="font-style:italic">yeah lapping it would give you better temps just dont try to remove it as i have heard AMD has started soldering the IHS to the die</div>
</td>
</tr>
</table>
</div>where did you hear that?
<tr>
<div>
Originally Posted by <strong>rabidgnome229</strong>
</div>
<div style="font-style:italic">where did you hear that?</div>
</td>
</tr>
</table>
</div>When that guy told the story of how he slaughtered is FX-62 lol
<a href="http://www.overclock.net/amd-cpus/121095-ihs-cpu-soldered-warning.html" target="_blank">http://www.overclock.net/amd-cpus/12...d-warning.html</a><br />
<br />
here ya go
<tr>
<div>
Originally Posted by <strong>MADMAX22</strong>
</div>
<div style="font-style:italic"><a href="http://www.overclock.net/amd-cpus/121095-ihs-cpu-soldered-warning.html" target="_blank">http://www.overclock.net/amd-cpus/12...d-warning.html</a><br />
<br />
here ya go</div>
</td>
</tr>
</table>
</div>It hurts me to look at that.
Check around for an Auto Body/Paint store. You can get individual sheets of sand paper rather cheep. Unless you know an auto painter/bodyman who can hook you up <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Discussion Starter #16
I bought the lapping kit from that EasyPCKits, <a href="http://www.easypckits.com/products/hslkwg/" target="_blank">http://www.easypckits.com/products/hslkwg/</a> . 6 bucks gets you 7 sheets of the different grade paper, and a piece of glass. Worth it for me just in the time saved looking for this stuff. Last time I tried for the sandpaper I couldn't find any store in the city that carried any over 800 grit. Had to go out to the suburbs and hit Auto Barn.
1 - 16 of 16 Posts
