1 - 10 of 10 Posts
What's the deal with the huge drops in performance on the RAID 0 array...the the drops in the single 80GB?
I'm debating whether a reformat would be in order for the 80GB. 640GB are the WD AAKS drives.
~Gooda~
Shouldn't be. I'm doing a clean install of Vista on the 80GB drive and will run benchies right after it's done (testing performance now).
~Gooda~
Sorry, got distracted with friends. Here's a bench of the 80GB boot drive after a fresh install of Vista.
Wdf.
~Gooda~
Wdf.
~Gooda~
Somethings up with that drive, thats horrible readings.
I would attempt a RMA if it was a spare drive you have lying around.
Originally Posted by Havegooda View Post
Did an error scan with HD Tune, all in the green -.-
~Gooda~
Look up the manufacturers specs on the drive, if its not performing to the specification than I would say that makes it qualify for a RMA because it isn't performing as advertised.
Every drive you can buy has a specification list of average response times, read and writing speeds. If it's dramatically below( which it appears to be) then obviously it's a faulty drive.
1 - 10 of 10 Posts
