Whats wrong with the temp???
654 9
I'm using 4 case fans, air inside is 27C/80F, and my CPU is 44C/111F idle, i uses AS5 with Zalman 7000Pure Copper HSF and i don't know why my CPU temp won't drop lower
1 - 10 of 10 Posts
Originally Posted by YiffyGriffy
Prescotts run hot
..............i know that!!!.............but other says that they runs it at (around) 30C, i mean how did they do that, they have the same equipment as me
30C is pretty cold.. maybe he lives in Canada, I mean even my processor doesn't run that cool and I have that gigantic Thermalright XP-120. And people with WaterCooling have higher idle temps than that. But I'm no Intel expert...
Linux Guru
I agree with the others, the fact that you are using a Prescott is why the temps as high, your idle now is 44C, mine was 46C with watercooling.
You should be happy that your temps are that low right now.
I don't see a cooling problem with your system.
1 - 10 of 10 Posts
