So I got a bluecreen twice playing warframe and the message read WHEA_UNCORRECTABLE_ERROR. Now I did some digging and saw it was hardware fail error. The first time I got it I ignored it, booted it back up and started gaming again. Then it happened again. So I have no clue what the issue is. First I thought it was an HDD problem, but then I tried to run a chkdsk and before running it said the drive is fine.
My temps look ok, according to HW monitor. CPU core 0 to 3 reads 85, 81, 83, 82. But the general readout for CPU is 69. Which is pretty high considering I have a corsair H70 (I believe). Now I'm still running warframe in the background and I am getting these temps.
Other temps (SpeedFan 4.49): GPU 40, Temp1 69, temp2 52, temp3 31, HD0 30, HD1 31, HD2 31.
HW mon shows some other temps which I don't understand: THRM 68, CPU 68, VREG 51, System 30.
Fans: CPU 1730-1750, JPPWR used to jump from 600-2800. Now it's stabilized at 1000-1060, JCHA 712-750.
For reference it's 25 degrees outside and my window is open, the tower is sitting under the window.
So what is the problem? The reoccurring BSOD, the weird fan speed of JPPWR? Could my psu be going bad? Is it the board? Is it the HDD? Is it the corsair cooler?
System specs:
Windows 8 pro
GTX660TI
i7-930 (oc to 3.14, 2.8 stock)
16GB Corsair vengeance (slight oc to around 1800)
EVGA x58 SLI
all WD barracudas at 7200rpm
HAF 922M
PSU is a 750W TigerPower (I can't remeber)
The PSU is the oldest part of my PC build, next to the HDDs.
Hope I'm not in the wrong section, I'm new to the forums and it's kinda confusing.
System specs:
Windows 8 pro
GTX660TI
EVGA x58 SLI
HAF 922M
