Like this with details:
That's normal, some sources will fail the stop command and will keep running but they'll stop sending errors.theres more if failed for example to disable some of the wheas
Try this version, replace what's in the installation folder:it did manage to block some of them tho.... im looping heaven and is around 147k before ufffff lol
Uhm, are you sure you replace it correctly?did that still error
You should get this message instead:Error Sources targeted to be disabled:
Type: 16 Description: WheaErrSrcTypeDeviceDriver = 0x10, Device Driver Error Source
Type: 0 Description: WheaErrSrcTypeMCE = 0x00, Machine Check Exception
Type: 1 Description: WheaErrSrcTypeCMC = 0x01, Corrected Machine Check
Type: 3 Description: WheaErrSrcTypeNMI = 0x03, Non-Maskable Interrupt
Type: 7 Description: WheaErrSrcTypeBOOT = 0x07, BOOT Error Source
Is that ok to run with loads of WHEA errors for daily use? I does not seem to get USB/audio instabilities. Also isn't is unsafe to go above 1.2V on VSOC?Not always possible to fix it, that's why there is the suppressor.
Sometimes despite all is working fine you keep getting WHEAs.
You probably need much higher VSOC, around 1.2-1.225V.
Maybe also a little bit more IOD, I was running 1140mV.
Depending on the sample you may also need more CCD, 900mV is low.
Usually at least 950mV, I was using 1050m
If they are only WHEA 19 and only because the FCLK speed, yes.Is that ok to run with whea errors due to IF OC?
This is pretty important.I mean it does not seem to show any instabilities and USB/audio dropouts, but yet to be tested for no performance loss.
I've been running it for almost a year and a half without any issue.Also, is it really safe to run VSOC above 1.2V because there are a lot of information that it is not.
As soon i have a chance i re check again. |
Ah no, you need to use the installer.so i uninstall the service as i used the installer....
i dl the portable which i replace it with the files you gave me and i got the following
Service does not exist. Going to install now
Oh yeahoh wow what sorcery is this??? we getting there
Very nice!so i got a few on reboot BUT NO MORE on 3d applications running if i close hwinfo and reopen it no errors on 3d applications..
