1 - 5 of 5 Posts
as Wrote in title i can't see the temp in cpuid mon after raid 0
but befor that it show normal
That's right. That's designed-behavior.
Your RAID controller has to be able to receive and interpret SMART monitoring information from the drive. Not many hardware controllers will do that. HostRAID / FakeRAID implementations won't have the capabilities.
so that normal !!!
Yes, it's normal.
Just put a fan in front / underneath your hard-drives if you're concerned about temperatures. A bit of active airflow over the units will drop the temperatures sufficiently.
Discussion Starter #5
Originally Posted by ComGuards
Yes, it's normal.
i will do that right now thanks dud
1 - 5 of 5 Posts
