Is that after you updated? If not then I would definitely go with the latest BIOS revision--they are inclusive, meaning (as far as I know) they each include the previous fixes and improvements.
If you started locking after the flash it is possible you may have corrupted the BIOS. In that case I am not sure there is a good fix short of a successful reflash of the BIOS
