1 - 10 of 10 Posts
hey guys just wondering where i can buy the black trim after im done modding a side window to put around the edges.?
You can get u channel at most hardware stores. That should suffice for the trim. Make sure you purchase enough to go around the edge of you cut out. I'd buy more than needed just in case. It is inexpensive. It is also great to use inside the case for cut outs, for cable management.
What department did you find it at? I've looked HomeDepot, Lowes and nothing. Maybe I will check local hardware before buying.
they dont carry it their best option would be goto a Pep Boys or AutoZone
1 - 10 of 10 Posts
