as far as tubing goes -- like tygon i guess -
can i get it at home depot? or do i have to buy online?
Originally Posted by Towlieee As long as your not going over 1/2" inner diameter (who does) then I think the home depot/lowes stuff is just fine.. 3/4" ID was way to thick to bend, but 1/2" makes plenty good bends.. Just make sure you get good quality ****... My first time buying 1/2" hoses I got the end of the line, and it was all flat and mashed and kinked =\\, every bend I tried to make with it, it kinked.. Then I went back a few days later and they got a new spool, and I got some perfect hose, and it bends just fine |
Originally Posted by newbieocer as far as tubing goes -- like tygon i guess - can i get it at home depot? or do i have to buy online? |
Originally Posted by Towlieee Ya hardware stores have them I'd suggest plastic onces since they seem to be slightly bigger... All my metal barbs leak without clamps on them, but the plastic ones done leak.. I think its a tighter fit |
