Where can I find my Viedo Card Drivers? Radeon 9550
1459 4
i just completed my first rig a couple months ago. Now I've decided I wanna overclock my graphics card. My cpu is already hot enough( 62 degrees F I'm in patio) but I wanna see if I can give my video card a boost.
Well first I have to find the most updated drivers for my card. So I've been to Ati's website, but I'm not sure which one I'm suppose to dl. I use Windows XP Pro. Plz help!
1 - 5 of 5 Posts
62' Farenheit with stock cooling is only 17C. Thats pretty damn awesome already.
just go to ati.com go to divers then select the os you have then from there choose radeon after that select what speed connection you have to dl the drivers then install them then to oc ur card go to guru3d.com dl ati tray tools and oc away but use the aotu oc to find a good oc for your card. and if you really want performace you could flash your card but that depends on what type of vpu core you have i would ask sphere about that he really is good on flashing vga cards up
1 - 5 of 5 Posts
