Where can I get acrylic?
538 6
Where can I get acrylic cheap? Perferingly not online
1 - 7 of 7 Posts
they said it pretty much.... hardware and glass shops...
Hi Bentrinh,
Buying acrylic on-line:
http://freckleface.com/shopsite_sc/s...cmaterial.html
I've bought from these guys. I don't know if the price is right for you though, or how much or how large you want the sheets. If you're doing computer cases or fish tanks, these guys are a start. If you're looking for window kits for your pc, then there are lots of places on the web. This is just one of many:
http://www.performance-pcs.com/catal...437a16e4cdc01b
Since you live in Los Angeles where I was born and raised for 43 years, there are many glass shops that might have bits and pieces for cheap prices. You'll need to call around and find it though.
I hope this helped, :)
1 - 7 of 7 Posts
