Where to and how high, core voltage
728 10
At how much can I start with core over voltage on 3060ti fe?
At these settings, highest I seen was 58c for a sec but 57c.
Core:2,115 MHz /Mem 1,979 MHz /Boost 1820MHz
Terrestrial plant Screenshot Font Electronic device Technology
1 - 11 of 11 Posts
It does add 10mv to max volts out to 1.1v. That’s all she gives you unless to modify the board directly.
proper shunt? no liq metal, soder.?
Discussion Starter · #8 · (Edited)
Iconoclast
The curve editor isn't new...it's pretty much been the default way to OC NVIDIA GPUs since Pascal.
Press CTRL+f in MSI AB and map the desired voltage to the desired frequency. 15MHz increments on Ampere. Curve shifts up or down slightly (15MHz at a time) depending on temperature, so make sure you tatke that into account to avoid over boosting.
dunno names.
v to f i dunno. never heard if it.
Discussion Starter · #11 ·
omg v and curve and others *** touch.
ampre has 3060ti? what is ampere?
i mght be tipsed, but im not a scientist.
i am gonna have to investigate for better.
im uncompreadable at the moment.
i do my best
1 - 11 of 11 Posts
