Originally Posted by RushMore1205
i looked on perfomance pcs but i only seem to find their work?
where do i buy the diy stuff?
also white size do i need just to do power supply cable?
and what others are used for?
Barry (FurryLetters from eBay) has some great quality sleeving. If you're only looking for black, the Techflex Clean Cut is great quality.
http://www.overclock.net/other-hardw...-sleeving.html
Unfortunately, the Techflex Clean Cut only comes in black and grey from the manufacturer. The colored sleeving that he sells is PET and isn't dense so you can actually see the wires through the sleeving. The only way around this is to either double sleeve using the PET or paint the wires.
MDPC is another option however, I only tend to recommend buying from here if you want colored sleeving. The reason is that it's really expensive. For $17 + shipping, you can get 100 feet of Techflex Clean Cut from Barry. I think the last time I checked over on MDPC it was like $40 USD total with shipping for 98.xx feet of sleeving (30 meters).
When comparing the black sleeving from Techflex Clean Cut to MDPC, the only noticeable difference between them is that the Techflex Clean Cut is glossier.
Now, from there, you'll need heat shrink tubing. Barry (FurryLetters) now sells 3:1 ratio heat shrink tubing for a pretty good price. You'll generally need 10 feet of heat shrink for every 100 feet of sleeving. 3:1 ratio 3/16th heat shrink fits perfectly over the sleeving and shrinks to a great fit. 2:1 ratio heat shrink works as well though and it's what I used.
