1 - 3 of 3 Posts
Hi all,
I need your help. I am looking for a rounded cup head metal clips for the side panel like in the attached pictures:
My brother need a new one because one of the clips was broken. I have tried to find it on google but i couldn't find it.
Many of the clips are flat with black rounded plastic.
Do you know what is the name of that clips i can find it??
And do you know where I can get it from??
Thanks in advance
You can get rounded head bolts from a hardware store. They usually have a square insert that goes into the cut out of whatever material you are putting it into. Alternatively just use a regular washer and screw, seems like the easiest fix.
I suppose a pop rivet could work, but.... What a pain.... You could probably contact customer support for the computer case and they might send you a spare.
How I can find out the name of the manufacturers of the case and model?
I cant remember the name of the case, but I think it is called ATX Galaxy or something like that.
If you can help me how I can find the name of the manufactuers of the case and model, I would be very grateful.
1 - 3 of 3 Posts
