I am going to buy Intel i5 2500k,have good psu, and wont to oc to 4 Ghz with lowest voltage possible. Red a lot of reviews,but I need personal expirience and I am hoping that I am on the best place that there is,and which of these boards are best for that task,longevity and quality of the board are prime concern,it must be z68 cause i plan to upgrade to ivy bridge next year on same motherboard,and if you have some other advice please tell.Budget is 210e max.
Thanks in advance.
Asus Gene Z (Gen 3) ~ not yet priced (155e non gen3 version)
Gigabyte GA-Z68XP-UD4 ~ 180e
MSI Z68A-GD65 (G3) ~ 165e
MSI Z68A-GD80 (G3) ~ 210e
Thanks in advance.
