So I've been trying to get my 4890 overclocked, and I'm having problems with the voltage, but despite that, I seem to have found two different variations of clocks that seem to be stable with no errors and I'm looking to see which you guys think would be better to use?
I currently have 971/1111 which runs well.
Or I have 980/1090 which works good too.
I really don't know if having a slightly higher Core would be better, or if having a slightly higher Memory but lower Core would be better.
In the past I've stuck with having a higher Core.
Also, if a higher Core is generally better, if I can get the Core to 1000 and lower the Memory drastically enough to keep it running without error, would that be a better bet?
Thanks.
Currently I have it set at the 980/1090 and will continue messing with it and see what you guys think.
Thanks.
