1 - 5 of 5 Posts
· Premium Member
I have narrowed my choices down to 4 options but am not sure which to get and I have to go right now so I dont have time to decide so I'll leave it up to you
G.SKILL DDR2 533 $36.99
http://www.newegg.com/Product/Produc...82E16820231016
OCZ Gold DDR2 667 $55.94
http://www.newegg.com/Product/Produc...82E16820227042
Corsair valueselect DDR2 667 $46.99
http://www.newegg.com/Product/Produc...82E16820145569
Crucial Ballistix DDR2 667 $95.00
http://www.newegg.com/Product/Produc...82E16820146557
Please consider price timing and speed (only the G.Skill is 533)
· Premium Member
Discussion Starter · #2 ·
Also, I could just add 2 more sticks of the same RAM I have, its about $37 per 512MB and it is DDr2 533, should I do that since it is by far cheaper and since I am not even overclocking any more DDR2 533 should be plenty (I run it at 400 to be 1:1 with my FSB and it allows me to tighten the timings down to 3-3-3-8) in fact when I was overclocked to 3.75 my ram was only DDR2 500 and if I got my dream OC of 1066FSB which would give me 4GHz right on the dot, that would also be DDR2 533 on the dot
· I remember when......
Well, it's ahrd to compare the g.Skill to the others......I mean, it's cheaper, but that's cause it's slower.
I would recomend the OCZ. Good timings, comes with heatsinks, reasonable price.
If you were going Corsair, the XMS series is only $7 more than the value select for the same speed and size.
Corsair 512MB DDR2 675
Timings are a little looser than the OCZ, but not much.
· Premium Member
OCZ baby, personnally i think OCZ makes some of the best ram out there...
1 - 5 of 5 Posts
