1 - 10 of 10 Posts
Hey guys,
Getting a 570 to replace my... 275. That's right a damn 275!
Primarily for BF3 and because well... it's a 275.
Choices:
http://www.pccasegear.com/index.php?...ducts_id=17117
OR
http://www.pccasegear.com/index.php?...ducts_id=17239
OR
http://www.pccasegear.com/index.php?...ducts_id=17812
Only getting one since I am saving for other stuff. I might SLI but I am fairly sure that makes no difference to card choice. However, if I was sure I wouldn't be asking which one to get.
So which one should I get guys?
And why if you can
e.g. better cooling or w/e
Cheers,
Fluidz
Go with the Gigabyte , its got those good long lasting components as well and is factory overclocked , all good components from a good company. For 30 $ more you are guaranteed a good overclock and a 2 slot card .
I had the direct cu , too long and heavy , too flimsy . Switched for twin frozr 3
Originally Posted by simoncow
Go with the Gigabyte , its got those good long lasting components and is factory overclocked . For 30 $ more you are guaranteed a good overclock .
Proof?? Nobody is guaranteed anything above what it comes out of the box.
***** Gigabyte RMA service.
On paper the Asus for sure, however I hope yours is a better overclocker than mine was. It needed 1.1v for 820mhz. It's been suggested that Asus doesn't bin the better chips for these cards so it's luck of the draw I guess.
1 - 10 of 10 Posts
