1 - 8 of 8 Posts
Yes I am doing last upgrade for DFI lanparty M/B..<br />
has 2 by 512 patriot xblk<br />
I have read somewhere that some of the 939 duelcores behave differently with T1 than others...<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
I like the 4600 because of its *12 multi and maybe high o/c because of less temp on silicon and perhaps good T1 compatibility due to the 512k caches-<br />
I Dont Know-<br />
The 4400 89 watt seems good too but this is the one I think I read wasent really made for T1 (maybe bad info...)<br />
The 4800 I like but prices have jumped 35 bucks in 2 weeks. and do 4800's run warm ??,do they consistantly go 2.9-3.0 on water???<br />
<br />
Any Ideas ?
I would definitely go with the 4400X2, first off it has the 1MB cache which will largely help on apps. Most users hit 2.6-2.7 on air, and >2.8ghz on water. Also awhile back some of the system specs were reset, please refill them.
Go for the Opty 165 imo, people are getting nice steppings recently and its the best deal dual core on 939 atm.
Discussion Starter #4
<tr>
<div>
Originally Posted by <strong>Niko-Time</strong>
</div>
<div style="font-style:italic">Go for the Opty 165 imo, people are getting nice steppings recently and its the best deal dual core on 939 atm.</div>
</td>
</tr>
</table>
</div>Ya thanks but I really wanted to run 1 to 1 on memory....can you tell me different..<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
well honestly i think that the ability to run 1t is more mobo and ram defined then cpu defined, i have ran my ocz plat rev 2 at 1t with multiple cpus of different types all the way up to 290mhz and it wasnt cpu but ram timings and ability of mobo to handle it<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103546" target="_blank">http://www.newegg.com/Product/Produc...82E16819103546</a><br />
this guy is good <br />
<br />
but i like this one becasue i had the worst stepping and still got 2.85 on water <br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103586" target="_blank">http://www.newegg.com/Product/Produc...82E16819103586</a><br />
<br />
<br />
and if you want a higher multi then the 170 then <br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103584" target="_blank">http://www.newegg.com/Product/Produc...82E16819103584</a><br />
<br />
my choice personally would be the 170 but thats just me G.L.
You can run 1t on the 165? Well, you could get the 170 then instead.
<tr>
</td>
</tr>
</table>
</div> yeah yo can run the 1t on any of them you either need really good ram or run a divider and even with the 170 hell still prob need a divider unless he has really good ocing ram,<br />
<br />
i think he should get what ever he can afford and oc the crap out of it, cheaper the better on the cpu (hence the real reason for ocing)
1 - 8 of 8 Posts
