1 - 15 of 15 Posts
I'm planning on building a new gaming rig, but I'm not quite sure what CPU to buy. I want an AMD 939 and I have about $300 dollars to spend on the CPU itself. I may spend a little more for the CPU, but nothing over $400. This rig will be completely for gaming so what would you guys recommend. I am 100% sure I am going to overclock the hell out of what I'm getting.
So to summarize my requestI need a 939, gaming, good overclocking, $300 CPU.
Thanks guys.
I'd go with an Athlon 64 X2 3800+. The dual cores will really help you a few months down the road when games start utilizing both cores. Also, it's a decent overclocker and right in your budget range. Either that or spend a little more and go for an Opty. They don't have the same stock speeds, but they run on lower vcores, have bigger caches, and are more overclockable.
Go for the x2 3800+. You can OC that to equal a 4600+ no problem.
Any DFI NF4 or Ati chipset should work for you...preferably the lanparty's
Reactions: iNiMiTabLE
Discussion Starter · #8 ·
I think I'll go with a DFI because like some of you mentioned, the OCing capabilities it has. I have heard of the chipset fan on the DFI being loud, but on my current rig I have 11 fans running 24/7 so noise is no problem for me.
So I've decided to go with the X2 3800+ with a DFI Lanparty. I'll make another thread later on when I decide on other parts and put it up for review before I make my final decision.
Thanks guys.
for me I would go with a.
AMD Athlon 64 3200+ Venice 1GHz FSB 512KB L2 Cache Socket 939
Model #: ADA3200BPBOX
Item #: N82E16819103535
This would be the best way to go .
This cpu is only $169.00, but you might be able to find this cpu probly $150.
Originally Posted by Xavier1421
My humble cpu suggestions:
Single core? 4000 San Digeo (330 shipped)
Dual core? X2 4200 Manchester (360 shipped)
Why did you choose the 4000 over the 3700? Just curious
Good question, not terribly sure. I guess the additional multiplier isn't worth the extra 105 bucks.
Good catch soccer! (I would have gotten the 4000 anyways, I love me the 12 multi on the AMD's....good cooling and decent PC4000 ram and wham, you're at 3GHz)
But what is wrong with an overclocked 3000+ for gaming, the cpu at the end of the day doesnt make a hell of a lot of difference in gaming, you get ya grunt from the gpu. Ya better off just spending more money on something else than a new cpu. (In my opinion of course) But if you are keen then have a look at a x2 4400 or even some of the optys. Buying these higher priced cpus like the 4400 will not give you a massive overclock compared to your 3000+. You will be paying for the cache and is it really worth it at the moment..........think about it.
I go the Opty 164 ... tons of cache and only slightly over your budget
1 - 15 of 15 Posts
