which ATI card?
498 Views 10 Replies 8 Participants Last post by  darksideleader
people on the forums helped me pick the 710 x3 and a gigabyte motherboard, which graphic card you think will be good for online games? mostly rpg? budget 150 for this one too.
1 - 11 of 11 Posts
0_o for that price, why ati?
and uh... rpg? as in mmorpg or single player stuff like oblivion?
http://www.newegg.com/Product/Produc...82E16814102770
ok heres another good one. i have this one bookmarked. sapphire 4850. for 139 free ship.
Sapphire 4850 1GB
http://www.newegg.com/Product/Produc...82E16814102802
$150
Will play everything out there. Might not completely max Crysis, but who cares.
If it's for MMO's - this card will easily max even the tougher ones, like Age of Conan.
4850 sounds good, i guess ill go for this one
why ATI? idk going with the mainstream. amd/ati thing lol
lol why not. yeah 4850 is good around that price
Go for the 1GB Sapphire model. It will help a lot at higher resolutions with texture pack type things.
Edit: Fill out your system specs!
4850 is good, 4870 is a bit better but probably overkill for you. Think 4850 is the perfect card for that price range.
+1 for 4850!
4850 should OC to 4870 with out issue. Since you want to keep it all in the family? AMD GPU Clock Tool. From AMD, I use and like.
1 - 11 of 11 Posts
