actually the ft02 has a special cooling system 3 fans on the bottom to cool all the components with the rotated mobo thingy so no side fan needed i believe that the define has 140/120mm fan slot on the side if a piece of a foam is removedOriginally Posted by Precision_PC;15331130
Correct me if I am wrong. But do either four of those cases have the option to add a fan/s to the side door?
That fan makes a big difference with GPU load temps. I could not imagine running my comps without one.
Although if I had to pick one of the four cases. I would go with the Silverstone PS06.
Originally Posted by Precision_PC ![]() Pretty easy choice if your ready to spend the money. Actually. How about comparing that case to other cases in its price range? Never hurts to shop around more. I've had numerous buys that I end up second guessing. http://www.newegg.com/Product/Produc...0%20-%20%24300 |
Originally Posted by Precision_PC ![]() Found the FT02 for $229.99 here. |
Originally Posted by Envadzer ![]() well i'm gonna wait till the poll ends and see what will other people say before buying and thanks you helped me a lot +rep ![]() |
