1 - 20 of 20 Posts
Im looking at the Antec 1200, I currently have an Xclio 380 which has oddly sized fans that are hard to replace compared to standard sized ones on the Antec-1200
Just curious if there is a Computer case with better air-air cooling than the Antec 1200, and has easy to replace fans, and is similar or cheaper in price.
BTW, I like big cases for the optional in-case watercooling they can potentially provide
PC Gaming Master Race
Antecs are horrible. Get a HAF or Cosmo S.
if water cooling is in your future, invest a bit extra in a 700/800d
otherwise, the phantom is a popular choice & great value at $140
How about the RV02? RV02E
Reactions: thecrapler
Originally Posted by wupah;12046683
both of those cases look like they're REALLY good quality, just curious, do you know if a noctua NH-D14 would fit in there ?
I was set on getting a MC HAF 932 but know i'm not so sure..
Yes, I own the XL and it fits great. The back fan is 140mm, but I use a 120mm with my H50, its also got silent damps on the doors and the front of the case, can't even hear it on it.
cm 690 II adv? im surprised nobody has mentioned it yet
as someone who currently owns a 1200 and has it housing his main rig, I would stay away with it. The airflow is good but it is not the most versatile case and at this point there are much better choices.
1 - 20 of 20 Posts
