So,
I'm building a new rig (check sig.) I already have the EVGA GTX 260, so the case would need to fit that, and if the 300 series are any bigger, would need to fit that as well incase I upgrade.
I'm doing a Blue and Black Theme.
So which case should I get?
Right now I have a no-named Mid-Tower and there's about 4 more inches of clearance before it hits my stand.
Cases I have picked out:
Full Tower:
HAF 932 (Red LED Fans swapped out with Blue LED Fans)
Antec 1200
Mid-Tower:
Antec 902
HAF 922 (Same as above for the 932)
Any other choices?
Which out of the 4 listed would you pick...(bearing in mind of the height issue)
Full Tower:
Antec 1200
Mid-Tower:
Antec 902
Any other choices?
