Which cooler is better?
355 Views 2 Replies 3 Participants Last post by  Cyberbot
http://www.newegg.com/Product/Produc...-355-_-Product
or
http://www.newegg.com/Product/Produc...-350-_-Product
Thanks
By better I mean which would cool better at the same noise level
1 - 3 of 3 Posts
Not sure either.. This one http://www.newegg.com/Product/Produc...-355-_-Product is more open and seems to blow the air directly onto the GPU while the other one is more closed but blows the air in a focused beam toward the GPU and let the heat escape out from the back of the GFX.
TBH I don't think there's any difference, if there is, it's most likely nothing more than 1,5C.
EDIT: About the noise level, I think it's pretty much the same for either of the cards.
1 - 3 of 3 Posts
