1 - 20 of 22 Posts
Is that CPU with 3.33Ghz like coming E6800 hard to overclock, since it is 3.33 already?
new processors? or old one's. pls be more specific. you really cant post a wide open question like that. its impossible to answer.
Huh?
No, overclocking is often relative. Ex: If a CPU is 2 GHz stock and you're able to OC it 50% to 3 GHz, it's likely that the 3 GHz edition could reach a 50% OC too (4.5 GHz). This is partly because the stock voltages on a fast CPU are the same as the stock voltages on a slow CPU (E8200 and E8600 have the same stock Vcore).
Man with Fans
He's saying, are CPU's with higher original clock speed harder to overclock as opposed to low clock speed CPU's?
e.g. i7-920 2.66GHz vs. i7-950 3.00GHz.
Chainsaw noise far off
PC Evangelist
It not hard but you dont have much room left. E8600 even at 3.33Ghz can still get 4.5Ghz which is still good.
Basically, processors from the same family (aka, first letter and/or number, such as an E8XXX, or 9xx) will overclock to about the same level. 920's will hit 4ghz, along with their faster (stock) 940 and 950 brothers.
I recommend a BSEL mod on an E3300 to 266MHz FSB for 3.33 GHz.
should be fine with stock volts, if not you can BSEL mod for more volts.
The way I understand it it all depends on stock voltages. Am I right? Less heat=higher overclock?
if not don't worry, i'm still a nub lol
I disagree.
As you can see here, here, and here, models with higher stock clocks generally have higher average OCs.
Ex: Phenom II 940 (stock 3 Ghz) gets an average OC of 4 GHz, which is 0.3 GHz higher than the average OC of a Phenom II 920 (stock 2.8 GHz).
Discussion Starter #16
I am using BSEL with E420, OC from 1.6 to 2.736. Actually E3500 is coming out too, do you think I can also BSEL E3500 or E6800? Those are newest coming out models.
Man with Fans
Originally Posted by SpookedJunglist View Post
The 3.8ghz Prescots were very hard to OC.
Are you looking for recent CPUs are are you just looking for a challenge overall?
And I take it as an exception due to its heat output and ridiculously high factory speed?
Discussion Starter #19
recent one, really for daily use. Since 775 socket CPU is pretty cheap except having a lot of cache kind, then I just want to buy a most updated one that is hard to OC then I just don't OC it with my intel motherboard, then I am happy with that.
Man with Fans
Most new CPUs are easy to OC....
The 3.8's are a real challenge though, as backed by Jung.
1 - 20 of 22 Posts
