1 - 6 of 6 Posts
ok i canget a p4 3.0 for 249 or a celeron 2.96 for 89 both new, whats btter 4 gaming???????? whats the diffrence. both sibgle core.
Go the P4, celerons suck. A celeron at 2.96, is like a P4 being at 2.0ghz, or less.
Where are you looking for buying these? Newegg has a P4 oem for 82.
I hope you are getting a whole system for that price including mobo, ram, case, vid card, optical drive, etc. If its just for the chip that is very expensive. You can get Core 2 Duo chip for that price.
Anyways, the P4 is better than the Celeron. One difference I know is that the P4 has bigger L2 Cache
I'd keep what you have!
Celeron will be worse than what you have now, and the 3.0 won't be enough increase in performance to be worth the $$
What motherboard do you have? With a good motherboard, PSU, and cooling, you might be able to overclock that current CPU you have a bit. At least a good bit over 3.0GHz.
What is your budget for upgrades?
For sure...if even if have a 533fsb...always oc before you upgrade!
With an increase in buss speed and cpu, you will probably be pretty pleased with the results + the cooler and RAM if purchased, could always go toward a future build. I just built a budget system for my father in law->
asrock 478 board- 43.00$
P4 2.53ghz/ 533fsb @ 3.15ghz- 38.00$
1g corsair ddr400- 72.00$
radeon9550 128m agp- 65.00$
80g barracuda- 50.00$
cd-r/dvd- 42.00$
Tt-BT - 48.00$
Ultra 600W/ 2x12v - 65.00$
= 423.00$
1 - 6 of 6 Posts
