1 - 6 of 6 Posts
Hi guys,
In the market for some more ddr3 ram which i will overclock some. My main interest is gaming. I am running windows 7 which from what i can tell 4gig should be sufficient. Please correct if wrong. Now the 3 memory sticks im looking at is the following;
G.SKILL Twin Pack RIPJAWS 2x2gig (4gig Total) DDR3 2000MhzCL9 (PC3-16000) F3-16000CL9D-4GBRH
Item Code memGStw_d3_4g16000cl9_rj
Specification
Main Board intel
System Desktop
System Type DDR3
M/B Chipset Intel P55
CAS_Latency 9-9-9-27-2N
Capacity 4GB (2GBx2)
Speed DDR3-2000 (PC3 16000)
Test_Voltage 1.6 Volts
Unbuffered
Error_Checking Non-ECC
Type 240-pin DIMM
$189
KINGSTON HYPER X TRIPLE PACK 6gig (3x2gig DDR3) CL9 1600mhz Model: KHX12800D3K3/6GX
Item Code memKGhyper_x_d3_6gig1600c9
KHX12800D3LLK3/6GX is a triple-channel kit of three 256M x 64-bit 2GB (2048MB) DDR3-1600 CL9 SDRAM (Synchronous DRAM) memory modules, with each module based on sixteen 128M x 8-bit DDR3 FBGA components. Each module kit supports Intel® XMP (Extreme Memory Profile). Each module has been tested to run at DDR3-1600MHz at a latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333Mhz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Price $ 199
CORSAIR DOMINATOR 2gig x 2 (4 Gig) DDR3 1600C8 1600mhz Model: CMD4GX3M2A1600C8
Item Code memCOtw_domd3_4g_1600c8
Corsair CMD4GX3M2A1600C8 4GB (2x XMS3 2GB) PC-12800 (1600MHz) DDR3 RAM, 2x240-pin DIMMs, Non ECC, Unbuffered, 8-8-8-24, XMS3 DOMINATOR with Dual-path Heat Exchange (DHX+ ) Technology, Core i7, i5 and Core 2
Price $ 219
Am thinking the corsairs personally, but would like to know other peoples opinion as i am no tech guru. I live value for money and wouldn't want to pay more for something if there difference is so minimal i wont even pick it up.
Thanks in advance guys,
Matt.
i think most intel users stick w/ trichannel. since i'm amd i have no clue whether this has a performance benefit to it but i would assume it has one just like dual channel. that said 4gigs is still sufficient for most current games.
although its not one of the ram tested. I was at the book store today and saw a article about memory from a uk pc magazine. it listed a triple channel kit from DANE ELEC and stated that it could oc up to 1300mhz! thats mind boggling if its for real.
Originally Posted by RyanBlackn View Post
The triple channel kit won't work in your system I don't think because LGA 775 motherboards operate with dual channel ram. Meaning 2x2GB. Get the Ripjaws. You will not notice any increase in performance with the Corsairs.
Can anyone confirm this? Also any other input?
This is a link to my mobo http://www.gigabyte.com.tw/Products/...ProductID=2851
Yes you have dual channel. And get the Corsairs, Mushkins or Cruicials. Get the 1333MHz or 1600MHz 7-7-7-20 2X2GB Dual Channel kit.
From your Mother Board page.
Dual Channel DDR3 1900(O.C.)
Experience maximum system performance with advanced DDR3 1900MHz(O.C.) memory technology, featuring higher bandwidth and increasing performance with lower power consumption.
* Please refer "Memory Support List" for memory support information
1 - 6 of 6 Posts
