1 - 4 of 4 Posts
can you recommend some? what do I need to look for, in terms of specs? I need 1GB sticks, that will run in dual mode. for my P4
Hello and welcome to the forum. Could you please fill out your system specs under the 'user cp' tab. This makes helping you much easier.<br><br>
As for the ram, what is your budget?
You normally need to look after memory that aren't seen "generic" (IE. Elixir, DaneElec, ETC.), and isn't of "Value" models. (Kingston: ValueRam | Corsair: ValueSelect, ETC.).<br><br>
There is several brands of RAM that is useful. The most known ones is "G.Skill" or the lesser known ones "CellShock", but still is extreme at overclocking.
Discussion Starter #4
<div>Originally Posted by <strong>TheLegend</strong></div>
<div style="font-style:italic;">Hello and welcome to the forum. Could you please fill out your system specs under the 'user cp' tab. This makes helping you much easier.<br><br>
As for the ram, what is your budget?</div>
</td>
</tr></table></div>
its a 3.4 P4 socket 478<br>
I wan to put at least 2gb (1gb sticks)<br>
GA-8IG1000MK motheroard<br>
250GB sata<br><br><br>
I'm not too pickey with ram, so then the cheapist but with good overclocking<br><br>
thanks
1 - 4 of 4 Posts
