Which DFI Board..
441 4
Hey guys placing my order tomorrow.. and i need to know which DFI board to get...Here is some specs im buying..
AMD X2 4200
OCZ 2 GB Memory
2 7800 GTX graphics card
Soundblaster Fatality Sound card
550 Antec Power Supply
Ive seen some reviews on Newegg that some DFI boards say they are SLI, but are actually not.
$200 LIMIT
1 - 5 of 5 Posts
AMD X2 4200
OCZ 2 GB Memory
$200 LIMIT
http://www.newegg.com/Product/Produc...82E16813136166
One of the best board on the market right now
and its $189
I would have to say the Expert. I'd also suggest not getting the OZC as I have heard they have problems with DFI boards. If you can go with out one gtx for now or find some extra cash, an x24400+ or Opteron 170 will do you better as they have the 1mb l2 cache on them.
SNERP!!!
OCZ is fine. They do sometimes have problems, but with a little troubleshooting it can work....and when it does you will be happy. Get the OCZ DDR4000 VX. It is great once you can get the voltage up on the board. I agree with everyone about the Expert. Everything on that board is much better then the older boards.
1 - 5 of 5 Posts
