1 - 4 of 4 Posts
Well for some reason, i cannot get my fsb past 429 (it occasionally works on 430) but the highest clocks i can get are :
429fsb (3ghz)
Ram : 858mhz
and
425fsb (2.97mhz)
Ram : 1133mhz
Anything inbetween those two does not post and if it does, exiting the bios results in no signal. I tried upping all the voltages just to see if it would work but nothing...so out of the two, which do you guys think is the better overclock?
What are the timings on the RAM? Also, have you trying overclocking unlinked? You may be able to get your FSB higher.
I don't think there's an unlink setting on this motherboard. And my timings are stock at 6-6-6-18 @ 2 volts
1 - 4 of 4 Posts
