Which way should I go, more bang(main worry) then buck(dont mind spending alittle)
  • 64gb SSD(OS), 4 black 640gb Raid 0
    Votes: 3 60.0%
  • 80gb SSD(OS and Apps), 160gb SSD(games), 320gb HD(The one in sig for leftovers)
    Votes: 1 20.0%
  • 160 SSD(OS, Apps, and some games), and 2 640gb Blacks in Raid 0
    Votes: 1 20.0%
  • Other (Plz Post your Other recommendation in the Thread, Thank you)
    Votes: 0 0.0%
Which do you think is more worth the money?
268 Views 5 Replies 2 Participants Last post by  Lysdexik
I started this thread to take a poll of which of this would you do if ordering an new i7 system. Starting to run out of time. I will be placing my order tomorrow afternoon. So I am on my final leg of finalizing what I will get.
1 - 6 of 6 Posts
Oh just seen this so could put in the poll, what about just getting one of this and just keeping my 320gb HD, maybe trading out later for 2 640gb Blacks raid 0.
Well I can tell you that I bought a 160GB X25-M for OS/Games/Apps and I thought that I may only need an 80gb drive, but it is funny how fast the drive fills up. You would be really happy with the 160gb drive, although I got a really good deal on mine, so it really depends upon how much you are willing to spend.
If you are going to spend that much on that one SSD, I would just get the X25-M.
Or spend a little more:
http://www.newegg.com/Product/Produc...82E16820227498
^^^ 750MB/s Read and 650MB/s Write
So would the 80+160gb SSD be better which is 240gb and a 320gb HD for left over. I normally have about 220gb or at times about 250gb at one time on this computer. but I want extra space for media like music or files I might need like scans etc.
Ok here is what I have come to. I just get a 160gb SSD(OS, Games and important and always used apps) and 640gb Black for everything else. Which comes to 800gb then something to back it all up. Or should i just get a 32gb SSD(for my OS only) then put in 4 640gb Black in Raid 0(for everything but OS). then a 2t extarnal drive for back up.
I would get the 160 and put your games and applications on it, they run SOOOO much faster I can't believe the speed!
1 - 6 of 6 Posts
