1 - 14 of 14 Posts
So, can you possibly give me a specific model of a DVD burner, that I could find on newegg for $40 or less?
Check out the NEC 3550a? (not sure about the last numbers), but I have a couple of them, and they kick butt! 16x +/- r and 8x RW and 4xDL doesnt get much better than that too. Right in your price range as well.
Discussion Starter · #11 ·
ok guys wow thanks! I think i will go with the lite on one...a local computer store, uses the same ones, so i think I will too! thanks!
Discussion Starter · #12 ·
OH, you are right, for $40 and under they ARE all the same. Of all the ones I have seen so far i have seen no difference besides the color, or brand name.
i would second the NEC 3500/3550a. i own them both and have been burning tons of DVDs with minimal coasters. i dont even remember the last bad copy.
they are under $40 at newegg right now
1 - 14 of 14 Posts
