which fan controller should I get??
Logisys fan master
NZXT Sentry 2
or Black Scythe KAZE MASTER
thank you
Logisys fan master
NZXT Sentry 2
thank you
Originally Posted by tincanman ![]() which fan controller should I get?? Logisys fan master NZXT Sentry 2 or Black Scythe KAZE MASTER thank you |
Originally Posted by FREELINE57 ![]() How about this sunbeam controller? |
Originally Posted by donutpirate ![]() Here is the FC4, it's only $29.99+ shipping... Currently, Newegg only has the silver model. That's the one I have, but I took off the front casing of it and spray painted it black and it looks great to me. ![]() It DOES come with a very short molex power connector, though.... I had to work some magic to get mine hooked up properly without messing up my cable management. If you have a molex extension, you would be fine. But if not, make sure you have adequate room for it to each. |
